To check the availability of the modem, Message Control sends the "AT+ CPIN" command to check if the modem is ready for sending. Several GSM modems have a different answer to the "AT+ CPIN" command to which the Message Control did not react properly.
An issue was addressed in the Message Control module that waited for an "OK" response from the modem. Several modems however do not send an "OK" message but only a "READY" message. Now, the Message Control module reacts properly on those responds too.
Fixed on 30.04.2012, available from 7.00 SP0 Build 1
Issue Number: 26770
Fixed on Date: 30.4.2012
Versions: 7.00 0 BUILD 1
