Memory usage for KUKA32 driver increases when reading variables which does not exist in PLC
When you define zenon variables which does not exist in the PLC program and use them in screen the driver allocates more and more memory in the runtime. This memory is never released.
with the fix the memory usage is normal.
Issue Number: 33802
Fixed on Date: 25.2.2015
Versions: 7.11 0 BUILD 18023
SNMPNG32 driver increases memory usage over time.
Summary The memory usage of the SNMPNG32 driver is increasing over time. DescriptionThe memory usage of the SNMPNG32 driver is increasing over time. Solution This issue has been addressed by improving the way variables are read. Issue Number: 36535 ...
IEC62056 driver increases memory usage when running for a longer period of time.
Summary The memory usage of the IEC62056 driver increases over time. DescriptionThe memory usage of the IEC62056 driver increases over time. Solution This issue was fixed by improving the way the request object gets deleted. Information The faster ...
StratonNG driver increases memory usage using RDA Arcives
Summary Each time that a RDA Buffer is read from zenon, the driver's memory usage grow up an will not be released. Description Each time that a RDA Buffer is read from zenon, the driver's memory usage grow up an will not be released. Solution Problem ...
OPCUA driver crashes when reading variables in background
Summary The OPC UA driver is terminated unexpectedly. This error has been fixed. Description The OPC UA driver is terminated unexpectedly when reading the PLC variables in the Engineering Studio via the command “Read PLC variables in background”. The ...
