MELSECA: When primary server comes back online (dominant) the MELSECA driver on the standby server is not stopped (keeps the TCP connection alive) and the MELSECA driver on primary can no longer connect to the PLC and therefore the variable gets invalid
TCP Connections are not closed on Driver stop
Issue Number: 221250
Fixed on Date: 8.7.2020
Versions: 8.10 0 BUILD 67223 | 8.20 0 BUILD 67231
    • FAQ: Initialization of Internal variables (Network) in Dominant redundancy mode.
      When (re-)starting the dominant Server 1, regardless of their 'Remanence' configuration, internal variables with calculation in 'Network' are initialized first in the dominant Server 1 and only after synchronized with the running Server 2. Modules ...
    • Checklist: Client/Standby cannot establish a reliable connection with Service Engine Server
