MELSECA: When optimized reading datapoints of internal Relay M with an offset range between two or more variables >= 480 words (7680 bits) then driver behaves unexpectedly
The MELSECA driver behaves unexpectedly when reading data points of the internal Relay M in an optimized way. Sporadically wrong values are displayed.  This occurs in an offset range between two or more variables >= 480 words (7680 bits). For word-based devices, such as "Link register", the error does not occur.
This behavior has been changed. The MELSECA driver now behaves as expected.
  • Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Item ID: 259974
Version: 11.00 Build: 117823
