Macro selection dialog is not shown on the monitor on which the screen is opened that triggered it
If multi monitoring is used, the macro selection dialog does not open up at the monitor which contains the screen that triggered opening this dialog. Occasionally, the dialog is opened at the most-left monitor or in the middle of two monitors.
An issue was addressed which affects the positioning of the macro dialog. Now, the dialog should appear on the correct monitor.
Fixed on 09.07.2014, available in 7.11 SP0 Build 13688. This issue can also be connected to a configuration in graphics driver, e.g. the AMD Catalyst Control Center which allows appearing dialogs to be repositioned on the screen.
Issue Number: 32195
Fixed on Date: 9.7.2014
Versions: 7.11 0 BUILD 13688 | 7.20 0 BUILD 17768
