LSIS Driver doesn't fit the read/write address If variable create the bool type.
The LS Industrial Systems XGT driver (LS_XGT)
does not use the correct read/write address for variables of type Bool. The driver writes to a
different address than it uses for reading. This behavior depends on the configured
type.
This error has been fixed. The LS_XGT
driver now considers the option for the PLC type and uses a different query for writing
Boolean variables depending on the configured type.
higher.
Item ID: 240902
Version: 12.00 Build: 180966
FAQ: When I activate the option "write synchronously" for the Recipegroup manager recipe, and I write the recipe, the recipe does not seem to be written properly and also the Service Engine does not close properly. Why is that?
When the option "write synchronously" is active at a recipe, when writing a recipe (sending values to the PLC) for each recipe variable a writing confirmation is requested to the driver. On a successfull write, the driver sends a writing confirmation ...
When using a driver in mode Simulation - programmed, in the zenon runtime an empty string of a variable of type string can`t be read when setting an empty string via the zenon logic workbench.
Summary An empty string can`t be read in the zenon runtime when using a driver in mode Simulation - programmed and setting an empty string via the zenon logic workbench. Therefore in the zenon runtime the string variable still shows the prior string ...
