LON32 driver closes when try to change the driversettings without correct 3rd party software
If the proper software (LON maker) is not installed it may happen that the driver stops unexpected when try to configure the driver settings.
improved the check routine for 3rd party components.
Issue Number: 29874
Fixed on Date: 8.7.2013
Versions: 7.00 0 BUILD 11 | 7.11 0 BUILD 10238
Checklist: Software-dongle is broken
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick hints] ...
Checklist: Communication to TwinCat via BeckhoffNG driver
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. TwinCAT ADS communication library ...
Driver configuration cannot be opened and also no new driver can be created.
If a Service Engine is started as a windows service also zenDrvOpsManager is running as a service. Thus zenDrvOpsManager cannot open a user interface for driver configuration and the Engineering Studio seems frozen. Running a Service Engine as a ...
FAQ: After which hardware changes I must expect to have to renew the software license?
The Algorithms used to calculate the license key are based on the Technology from Wibukey, various hardware and software components are considered. Which ones in detail is explicit Wibukey knowledge and not public information. In other words after a ...
