LON_32: When there are multiple driver instances, some of the driver-variables do not show status and values in the runtime
Depending on the configuration of a LON-Project, the driver is able to open a connection if the setting is OK. If a single connection fails on opening an exception is thrown but not shown as a message in the diagnose-window, because the window did not show up before the exception occurs. With this bug-fix the diagnose-window will be displayed before opening any connection and so the user can see what the problem is.
Issue Number: 242691
Fixed on Date: 24.8.2021
Versions: zenon Analyzer 3.40 0 BUILD 87645 | 10 0 BUILD 87728 | 8.00 0 BUILD 88189 | 8.10 0 BUILD 88647 | 8.20 0 BUILD 88924
