It is not possible to write on big blockarrays, if the PLC uses an EN2T/D communication processor.
Added additional property to connection-configuration. The new setting controls the max. data length for write request. default is 450
New property: Maximum block size for writing.
Default Value [Byte]: 450
Note: This value depends on the firmware used. It should only be changed if writing causes errors. The value is not always documented by the hardware manufacturer and must be empirically determined in that case. The default value worked with all known controllers in testing.
