Logix32 and LogixODVA driver: It is not possible to write values on large blockarrays (larger 500byte)
It is not possible to write values on large blockarrays (larger 500byte) in both Logix32 and LogixODVA Driver.
An issue has been addressed that in some cases (depending on PLC type) it is necessary to use shorter telegram length to read from PLC. Now the maximum telegram length is configurable (Default 473 Byte).
Issue Number: 31994
Fixed on Date: 28.5.2014
Versions: 7.10 0 BUILD 13311
