LOGIX_ODVA driver: Unhandled Exception when using a variable with "Block array size" >2
Allen-Bradley ODVA Treiber: Unhandled Exception when in the project there is a variable with "Block array size" >2 created on the Logix_ODVA driver.
memory access is corrected
Issue Number: 28456
Fixed on Date: 13.12.2012
Versions: 7.00 0 BUILD 6
