Logix_ODVA Driver can not communicate with PLCs using firmware revision 20
The Logix_ODVA driver does not communicate with Control Logix Compact Logix PLCs using firmware >= 20. The initialisation of the communication fails.
The driver initialize the communication now with the bit 'server' set.
Older Firmware Versions of Logix PLCs did ignore this byte, there will be no compatibility issue.
Issue Number: 26722
Fixed on Date: 2.8.2012
Versions: 6.51 0 BUILD 17 | 7.00 0 BUILD 3
