Logic Studio: Synchronization issue with "Load used projects only" in a multi project scenarios
Zenon Logic failed to synchronize variable changes because the "Load used projects only" option prevented referenced projects from being fully loaded. Variable renaming in the zenon Engineering Studio produced a duplicate in zenon Logic instead of updating the original, and newly added variables in loaded in zenon Logic projects were not created in the zenon project.
Item ID: 320540
Version: 15.00 Build: 669126
