Logic Studio creates files in %Temp% folder which does not get deleted
In Logic Studio, files are created in the %Temp% folder for an Add-In that opens the Studio via k5pi.dll. However, these files are never deleted. Each use of the Add-In adds new files.
This behavior has been modified. No more files are saved in the %Temp% folder for the Add-In. The required temporary file gets created in the zenon Logic folder and is deleted immediately after use.
  • If necessary, delete unwanted existing files in the %Temp% folder manually.
Item ID: 280392
Version: 14.00 Build: 239777
    • Checklist: The Logic Service to Service Engine connection does not work
      Time estimate:   30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • Checklist: Configuring the FTP Function Block in Zenon Logic
      FTP Connection Parameters: IPServer: The IP address of the FTP server. IPClient: The IP address of the computer where the data will be transferred. UserName: The username for accessing the FTP server. Password: The password for accessing the FTP ...
    • FAQ: Why do I get the warning ''unexpected file format'' while restoring loading a project in the Engineering Studio?
      Sometimes it can happen that old/deleted/corrupted screens are still in the project-SQL directory (C:\ProgramData\COPA-DATA\SQL[VERSION]\[PROJECT_GUID]\FILES\zenon\system\pictures). Once you know the corrupt file in this folder you can delete it and ...
