Loaded, modified, and stored archive capsules are corrupt
In Historian, completed archive capsules are corrupted under Linux if they are completely re-saved. They have an incorrect file size or the archive files are not compatible with the Service Engine under Windows OS. This means that the data created by the Service Engine under Linux is not read or listed via the archive revision screen with the Service Engine under Windows OS.
This problem has been fixed. The archive capsules are saved correctly again under Linux. The issue of incompatibility between the different operating systems (Windows and Linux) has also been resolved.
Item ID: 269325
Version: 12.00 Build: 180966
    • Process Recorder: Archive data creation during active playback mode
      Summary ARX files are created in the playback mode of the process recorder. This behavior has been modified. Description The Service Engine creates archive files (*.arx) during the playback mode of process recorder. But during active playback mode no ...
    • Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
      Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
    • Project in zenon Logic takes long time to Build external POUS when added manually
      Description zenon Logic projects take a long time to load external POUs manually. This behavior has been modified. The loading times of POUs have been significantly reduced. To benefit from this fix: Update your zenon Software Platform to the latest ...
