When a linear value adjustment is configured at a variable, this is not correctly considered in all circumstances in the Recipe Groups Manager. At reading and writing shadow variables and recipes, the adjusted range is not considered, and a "value out of range" occurs, which is represented via the system driver variable for the status of read recipe / write recipe.
An issue has been addressed in the Recipe Groups Manager module where the linear value adjustment was not considered correctly. Now the linear value adjustment is considered and the correct value is read / written.
available from 7.00 SP0 build 6
