Limit value display in GANTT chart in extended trend is not correct when using a reaction matrix for the limit
An incorrect value (1.797 e+308) is displayed as text in the GANTT chart in the extended trend when the variable for the GANTT chart uses a reaction matrix rather than a limit.
An issue was addressed in the GANTT display of the value as text of the violated limit, when instead of limits a reaction matrix was used. Now the value is also displayed correctly when using a reaction matrix.
Issue Number: 26782
Fixed on Date: 16.1.2013
Versions: 7.00 0 BUILD 6
Gantt chart is sporadically disappearing/blinking
Description In the Extended Trend, the Gantt chart does not behave according to the project design in some constellations. It disappears or flashes unexpectedly. The problem remains until the value is changed. This behavior has been corrected. The ...
ETM - Gantt chart is invisible with standard settings
Summary When you activate the Gantt chart in the extended trend and you leave the default setting for "Line width" (=0), then the Gantt chart isn't displayed. The problem is, that the standard setting = 0 and this setting is treated different in the ...
Extended Trend: Line Chart exceeds Y-Axis limit when another Gantt chart is active
Summary When Gantt Bars where drawn, the curve "height" was extended with the height of the gantts and their gaps. Now the curves end always with the y-Axis. Description When Gantt Bars where drawn, the curve "height" was extended with the height of ...
Gantt Trend dont recognize variable value 32768
Summary Gantt display in ETM did not correctly handle values outside -32000 ... +32000, so the limit 32768 (hex 0x8000, bit #15) was not recognized. Description Gantt display in ETM did not correctly handle values outside -32000 ... +32000, so the ...
"Export CEL" function cuts off the Limit Value Text (by using CSV Export)
In some cases the "Export CEL" function will cut off the Limit Value Text (by using CSV Export) by projects converted from older versions. To fix this effect you need to create a new "Export CEL" function in actual version.
