Legacy double bit binary input variables of the DNP3_TG driver with an offset > 255 are invalid in the runtime
Legacy double bit binary input variables of the DNP3_TG driver with an offset > 255 are invalid in the runtime. Legacy double bit binary input variables with a lower offset than 255 correctly combine two regular binary input points into a virtual legacy double bit point.
An issue has been addresssed where the offset for legacy double bit binary input was limited to 255. Now this limitation has been removed and binary input points can be combined up to the maximum possible point index -1 in DNP3.
Issue Number: 34641
Fixed on Date: 15.6.2015
Versions: 7.20 0 BUILD 20544
