Running the Language Table Wizard corrupts the project. This has been fixed.
The Language Table Wizard causes errors when run with the options "Convert texts into keywords" and "Linked symbols". The entries in the language table do not match the expectations and released properties are defined as keywords. This destroys references to other objects. Also, color information becomes invalid.
The bug has been fixed. A filter was implemented for this reason. This fetches the property type of the symbol group from the symbol library and uses it when setting the keyword in the symbol.
