Language file (zenon 11) - Import-CSV via API opens Language-file-import - wizard/popup
When importing a CSV file into the
language file via API, the wizard for importing language files is activated.
However, this wizard cannot be operated via the API.
Solution:
This behavior has been changed. When
importing via API, the wizard is no longer activated.
To benefit
from this fix:
- Update your
zenon Software Platform to the latest build of zenon 11 or later.
  Item ID: 255526
 Version: 11.00 Build: 106404
- Related Articles
- zenon Changesets CSV- Here, you can access a comprehensive list of changes across all maintained versions of the zenon Software Platform as Excel Worksheets. This includes both implemented bug-fixes and new features. Additionally, these lists are available in as Excel ...
- zenon Changesets Excel- Here, you can access a comprehensive list of changes across all maintained versions of the zenon Software Platform as Excel Worksheets. This includes both implemented bug-fixes and new features. Additionally, these lists are available in CSV format ...
- Engineering Studio crash if you import csv file to the AccessIec870Sl- Description The zenon Engineering Studio closed unexpectedly when the particular CSV file was imported to the AccessIec870Sl. The issue has been addressed and the import works now as expected. To benefit from this fix: Update your zenon Software ...
- Smart Object API : Variable mapping not applied after changing in engineering studio- Summary Changes in the variable mapping of a Smart Object instance are not applied during CSV export via SmartObject Export Wizard. This behavior has been changed. Description For a new Smart Object instance, variables are mapped in the Engineering ...
- API Error when running Instance Wizard (GSK)- Description If a Smart Object instance is created with the Instant Wizard (GFK) and removed again with this wizard, an API error occurs when another instance is created. The error message refers to: "Attempt to read or write protected memory." This ...
