KIEBACK.exe driver enhanced serial port support
The kieback.exe driver has been enhanced to support communication of up to 256 COM ports
Issue Number: 153418
Fixed on Date: 16.10.2018
Versions: 8.00 0 BUILD 52082 | 8.10 0 BUILD 57250
    • Driver configuration cannot be opened and also no new driver can be created.
      If a Service Engine is started as a windows service also zenDrvOpsManager is running as a service. Thus zenDrvOpsManager cannot open a user interface for driver configuration and the Engineering Studio seems frozen. Running a Service Engine as a ...
    • The COM tab of the driver dialog should support a selection from 1 - 256 serial interfaces.
      Summary In the COM tab of the driver dialog it should be possible to select between 1 - 256 serial interfaces. DescriptionIn the COM tab of the driver dialog it should be possible to select between 1 - 256 serial interfaces. Solution This issue has ...
    • Support of TIA V18
      TIA V18 is supported by the S7-1200/1500 (S7TIA.exe) driver from zenon 10/11/12/14 and higher with builds higher than 157700. All older versions of zenon are not supporting TIA V18. To confirm the support of TIA18 check in the installation directory ...
