It should be possible to display long variable names in the archives dialog when the extended trend and report viewer screens data origin is the archive.
Long variable names do not fit in the historian tree of the extended trend and report viewer screens archives dialog, so that when the ending part is in view by scrolling, the beginning part is no longer visible.
The archive variable selection dialog window can now be resized in the editor and runtime so that long variable names can be displayed. The last size and position used are only retained in the editor.
Issue Number: 33392
Fixed on Date: 30.1.2015
Versions: 7.20 0 BUILD 17768
FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
FAQ: How can I create long term Wireshark sniffs?
In this example it will be used OPC UA protocol as example to show how to use and configure a long term Wireshark captures. This is the best option when troubleshooting a connectivity/network issue occurring sporadically and it is not possible to ...
