It should be possible to create RT files for the current build of zenon 7.20
Additional to the possibility to create RT files for 7.20 it should be possible to create RT files for the current build of zenon 7.20
There is now the possibility to create RT files for the current build of zenon 7.20.
When driver extensions are made available for a specific build of zenon 7.20, these extensions will only be available in zenon 7.20 with the respective build version. When having a project in a higher zenon version, e. g. 7.50, and then compiling RT files for version 7.20, the driver extensions will not be available. Now when having a project in a higher zenon version, e. g. 7.50, there is the possibility to create RT files for the current build of zenon 7.20. !Use this option only if you really know you need this new enhancements in Drivers! If the build numbers of your current zenon Version and the target 7.20 version differ too much it can lead to not working Drivers.
Issue Number: 36289
Fixed on Date: 14.4.2016
Versions: 7.50 0 BUILD 27465
    • Checklist: Software Platform build update fails
    • FAQ: How to import external vector graphic files in zenon?
      Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
    • Engineering Studio crash after create all service engine files of the demo project
      Description The Engineering Studio closed unexpectedly when all service engine files of the demo project were created. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software Platform to ...
