It should be possible in zenon to communicate with devices which are compatible with the NMEA 2000 protocol.
The NMEA2000 Driver has been developed to allow zenon to communicate with devices which are compatible with the NMEA 2000 protocol.
Issue Number: 35147
Fixed on Date: 5.11.2015
Versions: 7.50 0 BUILD 25796
    • It should be possible in zenon to communicate with devices on a Masterbus Network.
      Summary It should be possible in zenon to communicate with devices on a Masterbus Network. DescriptionIt should be possible in zenon to communicate with devices on a Masterbus Network. Solution The Masterbus32 Driver has been developed to allow zenon ...
    • Password change at first user logon works via operating system but not via zenon SE ; no AD login possible
      Description In the Edge Gateway frontend, the user password can no longer be changed in MS Active Directory, when the zenon system is not a member of the domain. Despite correctly entering the previous password and the new password including password ...
    • zenon logic: 1 gain FB with LD can't assign a structure to a structure
      Description In zenon Logic it was not possible to add a structure to a structure in LD. However, this is possible in ST and FDB. As a workaround, you can activate the "LD optimizations" option in the project settings in LD. This behavior has been ...
