It might be possible to interact with the Editor when the driver configuration dialog is opened.
When a driver configuration dialog is open, clicking anywhere in the Editor will cause the action to be processed when the driver dialog is closed.
The interaction with the Editor has now been disabled if a driver configuration dialog is opened.
Issue Number: 35837
Fixed on Date: 9.11.2016
Versions: 7.60 0 BUILD 36068
Driver configuration cannot be opened and also no new driver can be created.
If a Service Engine is started as a windows service also zenDrvOpsManager is running as a service. Thus zenDrvOpsManager cannot open a user interface for driver configuration and the Engineering Studio seems frozen. Running a Service Engine as a ...
The MATSUTCP32 driver configuration cannot be opened in the editor
Summary The MATSUTCP32.EXE (Matsushita TCP-IP) driver configuration does not open in the zenon 7.10 32 and 64 bit editor. The driver cannot be configured DescriptionThe MATSUTCP32.EXE (Matsushita TCP-IP) driver configuration does not open in the ...
Checklist: Communication to TwinCat via BeckhoffNG driver
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. TwinCAT ADS communication library ...
Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
Redundant License Configuration
Starting from zenon version 8.00 it is possible to share each license over the CodeMeter network. This allows you to have a dedicated license server. The license server can be any PC or virtual machine which runs CodeMeter. One license for two ...
