Using Driver Exchange in Engineering Studio on an existing driver, it was possible to set the same name for many drivers. In this case it was also possible to use double names with the same driver type. Using double driver names can lead to incorrect driver communication.
The issue has been addressed and a driver name can now only be used once.
Item ID: 295846
Version: 14.00 Build: 372277
