It is not possible to use the zenon logic I/O driver Ethernet/IP Adapter in combination with the Logic to SCADA connection driver.
It is not possible to use the zenon logic driver Ethernet/IP Adapter in combination with the Logic to SCADA connection driver. When starting the runtime following message appears: "Opening bus driver"T5EIPS" for cold resp. warm start failed". If you only use the "Ethernet/IP Adapter" driver, everything is fine.
Changed runtime behavior, both driver can be operated together.
Issue Number: 32944
Fixed on Date: 29.10.2014
Versions: 7.11 0 BUILD 16009
    • T5BusEIPS: EtherNet/IP Adapter does not make use of TCP Keep Alive
      Description The EtherNet/IP Adapter (T5BusEIPS) does not make use of TCP keep alive messages to check if the TCP connection from an EtherNet/IP Scanner is still OK. The issue has been addressed and the T5BusEIPS enables a TCP keep alive for the ...
    • Interface settings for using an Ethernet port for Fieldbus communication in zenon Logic (e.g. ProfiNET)
      When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
    • zenon Logic: Ethernet/IP Adapter and Ethernet/IP Scanner will not be started in Logic Service
      Description In zenon Logic ServiceEthernet/IP Adapter and Ethernet/IP Scanner are not started, although they were configured correctly in Logic Studio. When starting the Logic Service they are not started as expected. Diagnosis Viewer logs indicate ...
