It is not possible to set negative values with the BeckhNG Driver on Windows 7 embedded compact.
Under Windows 7 embedded compact it is not possible to send negative values with the beckhNG from the zenon runtime to the PLC.
This issue was addressed by improving the way negative values are transmitted from zenon runtime to plc.
Issue Number: 36273
Fixed on Date: 8.4.2016
Versions: 7.20 0 BUILD 27570
