In the runtime, it is not possible to edit a user group and change the authorization levels for the group. An Admin user should be able to edit user groups and set authorization levels for the user groups. (only those authorization levels that the admin user itself has)
User administration in the runtime has been enhanced so that an Administrator user can now edit authorization groups. An administrator can only add those authorization levels to a group, which it has itself. An administator user can only remove authorization levels from a group which it has itself. An administrator user can only delete user groups for which it has all configured authorization levels. It is not possible to rename a user group.
Issue Number: 28064
Fixed on Date: 31.10.2012
Versions: 7.00 0 BUILD 4
