It is not possible to complie a project with the HTML Web Engine Compiler, if one frame has a freely defined shape
If a freely defined frame does exit in the project, the following error appears:
"Freely definable frames are not supported. The frame and corresponding screens will not be available in the HTML Web Engine. "
This error message also appears when the frame is not used in any of the HTML Web Engine screens.
 An issue has been addressed in the zenon HTML Web Engine Compiler, where the use of a freely defined frame only causes an error if it is linked to a screen, which is available for web.
Issue Number: 36392
Fixed on Date: 14.2.2017
Versions: 7.50 0 BUILD 29630
