Issue with zenon logic block name of a smart object at its instantiation
When instantiating a Smart Object, the block of a zenon Logic Project is not instantiated correctly. The name of the block does not match the rules in the instances and thus cannot be used as expected.
This behavior has been changed. Blocks are now instantiated correctly.
Item ID: 245139
Version: 10.00 Build: 113329
    • Smart Object: zenon logic Variables getting deactivated
      Description Smart Object Templates contain structure data types for zenon Logic. When changes are made to these templates, all structure elements in all instances of this template are inadvertently deactivated. These structure elements can not be ...
    • zenon logic: Unexpected complex data in expression
      In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
    • Smart Object Templates: Engineering Studio crashes when importing an XML file which contains an already existing function name in Smart Object
      Description The zenon Engineering Studio was closed unexpectedly when an XML file was imported that contained a function name that already existed in a Smart Object. The issue has been addressed and the behavior is now as expected. To benefit from ...
