"Invalid project folder" error message is displayed on creating a zenon logic project for programmed simulation with certain drivers
With certain drivers it is not possible to create a zenon logic project for the programmed driver simulation. An error message is displayed: "invalid project folder"
This concerns the following drivers:
  • 3S_32
  • 3S_Arti
  • 3S_Arti_NG
  • 3S_V3
  • 3964R32
  • 3S_32
  • 3S_Arti
  • 3S_Arti_NG
  • 3S_V3
  • 3964R32
An issue was addressed where the suggested project name for the project for programmed simulation was not compliant with the naming convention, as it started with a number.
Now the all invalid characters are correctly replaced with an "_", including a number as the first character, and in a new project a project for the programmed driver simulation can be created correctly.
The fix in this build will only work for new drivers for which no attempt has been made to create a driver simulation project.
If an attempt was made to create a driver simulation project in a version where the issue existed and the error message was displayed, the incorrect project name for the driver simulation project is stored. Applying the build with this fix will not resolve this. Instead it is required to rename the suggested name for the zenon logic project for the programmed driver simulation in the Drivers table of the SQL database for the project. Renaming the suggested name is also a workaround for this issue if the build is not installed. Contact your local support for further assistance if you face this issue and are unsure how to rename the name of the zenon logic project for the programmed driver simulation in the SQL project database.
Issue Number: 29978
Fixed on Date: 2.8.2013
Versions: 7.10 0 BUILD 7192
    • FAQ: What are the different zenon drivers modes?
      All Service Engine process-driven drivers can run in four different modes, mainly allowing you to switch between active hardware connection and values simulation. While "Hardware" allows establishing a connection to the target device(s) and its the ...
    • Engineering Studio: Add Driver 'Siemens : S7 driver for S7-1200/1500' to Zenon Project - Error when starting driver
      Summary The S7TIA/S7 for S7-1200/1500 driver cannot be started. This issue has been solved. Description The attempt to add the driver S7TIA/S7 for S7-1200/1500 to a project fails in some constellations with an error message (Error code 0x8001011f). ...
    • zennetsrv closes unexpectedly without an error message when receiving a specific invalid message
      Summary The zenon network service (zenNetSrv.exe) is closed unexpectedly when receiving invalid messages. This has been fixed. Description If in a zenon network the server receives invalid messages, the zenon network service (zenNetSrv) is closed ...
