In the Batch Control module it is possible to select multiple recipes in the recipe list and then press the DEL key to delete them alltogether. Before they are actually being deleted, a dialog pops up where you need to confirm you really want to delete them. By default, "no" is selected in this dialog. However, when you click "yes" to delete the first selected recipe, then "yes" will be selected in the second confirmation dialog. Normally, also for the second dialog "no" is the default selection.
The default selection in this dialog has been changed to "no".
