When the
Online Change option was enabled, a Libraries error popup occurred even for projects that did not use Libraries.
The issue has been addressed and for projects, that do not use Libraries and were created before the build update, the fix will take effect only after disabling Project Settings → Online Change, closing Libraries, and then re-enabling Online Change.
Projects created after the build update will no longer trigger the related error popup.
