If you use the "Signature without password" property and login with another user name via the Login Function, there is an Inconsistency in CEL Recordings.
If you login two times (one time via the Signature without password Login Dialog and one time via the normal Login Dialog) the CEL and other Records will show two different usernames if you change a value that has Signature without password enabled for the Modification and the Signature.
