inconsistant usability behavior in zenon logic profinet device configuration
zenon logic profinet device configuration: there is an edit box instead of toggle check box when editing the master properties « Initialize IOxS » and « I/O communication only from within cycle » there is an edit box instead of a toggle check box.
changed element Type with new build.
changed GUI, no changes in parameter storage.
Issue Number: 34043
Fixed on Date: 20.3.2015
Versions: 7.20 0 BUILD 18778
Interface settings for using an Ethernet port for Fieldbus communication in zenon Logic (e.g. ProfiNET)
When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
