In zenon network on client the command input called via context menu can cause an unhandled exception.
The Runtime on the zenon network client can terminate with an unhandled exception when attempting a command input via the context menu. On the network server or in standalone project the command input works correctly.
The relation to the variable for the menu is corrected now.
Issue only in 7.10 since 12.09.2013 (thus only in build 7770).
Issue Number: 30611
Fixed on Date: 18.10.2013
Versions: 7.10 0 BUILD 8129
