In zenon Network, if the command screen can't allocate the NET_SEL status bit and gets it later, then it will not refresh the bit.
If response variable has already the status bit NET_SEL - "selected in zenon Network" - and the user opens the command screen, then he does not get the access and must wait until a user on another Network client finishes to operate this variable.
If now the originator screen is closed, the second command screen gets the NET_SEL correctly, but is not doing refresh of NET_SEL. Thus after the timeout on process Server (10s) the NET_SEL is shortly lost and again allocated.
Now also by later allocated NET_SEL the refresh is processed correctly.
Issue Number: 32453
Fixed on Date: 24.11.2014
Versions: 7.50 0 BUILD 25796
