In zenon 7.11 it should be possible to enter an ip address as well as a hostname as string for the Network Connection of the S7TCP Driver instead of having four numerical fields for the ip address as before.
When a hostname entered for the Network Connection of the S7TCP driver can`t be resolved, the given string will be interpreted as IPV4 address.
This issue was addressed by downgrading the possibility to use besides the ip address also the hostname for the Network Connection of the S7TCP Driver to zenon 7.11
During a Driver enhancement between 7.20 and 7.50 the possibility of entering a hostname instead of a IP address has been introduced. this enhancement is now also available for the latest build of 7.11
Issue Number: 36034
Fixed on Date: 18.3.2016
Versions: 7.11 0 BUILD 26578
