Command Processing by Watchdog timer 'none' sets the PROGRESS status bit of response variable (RV) after Select confirmation and keeps until PLC responds with Execute activation termination - COT_actterm (10).
The PROGRESS bit should gone already when Execute confirmation, not termination, comes - COT_actcon (7), like it is by Watchdog timer 'only RV'.
Now, the command action - by watchdog timer 'none' and SBO active - resets the status bit PROGRESS when COT_actcon is received.
Issue Number: 30052
Fixed on Date: 11.12.2013
Versions: 7.20 0 BUILD 17768
