in the version 12 the connection with the S5TCP driver does not work
As of zenon version 12, the S5TCP driver
cannot establish a connection to the PLC. The problem does not occur in
versions prior to zenon 12. Connections that work in version 11 or earlier can
no longer establish a connection after conversion to version 12.
This error has been fixed. The connection works as
expected again.
higher.
Item ID: 269234
Version: 12.00 Build: 180966
Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
T5BusEIPS: Idle TCP connections are not automatically closed.
Description The EtherNet/IP Adapter (T5BusEIPS ) does not close TCP connections when these are idle and do not send any data. This can lead to a denial of service for valid EtherNet/IP Adapter when the maximum number of 124 TCP connections are used ...
