In SOT screens: File names aren't replaced for property groups
file name properties in symbols aren't replaced in SO instances if they are used in grouped released properties
resolve symbol to element group
Issue Number: 243017
Fixed on Date: 3.8.2021
Versions: 10 0 BUILD 87728
SOT: Screen element property changes its value when copying the screen
Description When a screen is copied in a Smart Object Template, the values of some properties might be modified undesirably. In the copied screen, they receive a new value. This behavior can also occur if the screen is copied in an SOT instance. This ...
Editor: Two screens with same file name can be opened once, after closing them and again attempting to open them nothing happens
Description If two screens in two projects have the same file name, an error occurs in Engineering Studio (aka Editor) after opening both screens. Identical file names occur, for example, when copying a project. Both screens can be opened once at the ...
S7TIA Driver: Variable names or Groups containing Umlaut (ÄÜÖ...) cannot be imported correctly.
Summary Importing Variable names or Groups containing Umlaut into the zenon Editor does not work correctly. The umlaut (ä, ö, ü) is not translated correctly and is displayed using Special characters. DescriptionImporting Variable names or ...
zenon Editor – Wrong naming of user groups of global project.
Summary When one user group is linked to a user there is always a user group called like the last projected global user group. It could be hardly distinguishable which one is from the global project and which one is from the standard project. If the ...
SOT replacing rule does not work after change on SOT if SOT is referenced in other SOT
Description A Smart Object Template (A) is referenced in another Smart Object Template (B). After changes in SOT A, the already existing Smart Objects of SOT B are unusable. Screens no longer work. However, newly created Smart Objects work as ...
