In PGW ICCP Server the feature 'SBO (routing)' does not work
The Process Gateway ICCP server failed to execute 'SBO (routing)' commands after a successful Select because it never forwarded the Execute step to the driver, causing a timeout and a subsequent negative response to the remote ICCP client.
Item ID: 317449
Version: 16.00 Build: 663171
