In Docker-Compose: no TCP keep alive for listening socket, port 50780
In Docker the TCP server of process zenLogSrv.exe did not send a TCP keep alive to check if the TCP connection is still available. The issue has been addressed by automatically enabling TCP server now automatically enables the TCP keep alive for the listening socket 50780 to clear TCP connections that are no longer available.
Item ID: 288600
Version: 14.00 Build: 314355
Version: 12.00 Build: 301428
FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
zenLogSrv: no TCP keep alive for listening socket
Description The TCP server of zenLogSrv.exe did not send TCP keep alive messages to check if the TCP connection is still available. The issue has been addressed by automatically enabling TCP server now automatically enables the TCP keep alive for the ...
Remote-Transport: no TCP keep alive for listening socket
Description The TCP server of process zensysSrv (used for remote transport) did not send TCP keep alive messages to check if the TCP connection is still available. The issue has been addressed by automatically enabling TCP keep alive for the ...
T5BusEIPS: EtherNet/IP Adapter does not make use of TCP Keep Alive
Description The EtherNet/IP Adapter (T5BusEIPS) does not make use of TCP keep alive messages to check if the TCP connection from an EtherNet/IP Scanner is still OK. The issue has been addressed and the T5BusEIPS enables a TCP keep alive for the ...
