The tooltip indicates after the unit allocation the status as allocated. If response variable has already NET_SEL (“selected in zenon Network”) status bit set, this is not indicated,
E.g. when a user opens the command screen and then the sequence is started acting on the same data point. The tooltip of the allocation object will display that everything is ok.
The toolbar considers now also that it wasn’t possible to get NET_SEL and not only that the response variable is used by another sequence.
Issue Number: 34090
Fixed on Date: 2.7.2015
Versions: 7.50 0 BUILD 25796
