In command screen the two-hands actions do not work anymore (up 7.0) - pressing CTRL activates display of "Execute2" button and it changes look by first click on, but then when you release the button it does not execute the action. It happens even when Lasso is deactivated. Workaround is to activate for Execute2 button the property "Function execution on pressing" - then it works. Per default this option is not active.
Issue was addressed in the check procedure for multi-selection of elements; the deactivation of Lasso is now recognized. Will be followed with #28298 to per default deactivate in templates lasso for 'Execute 2' button.
Fixed on 29.10.2012; available from 7.00 SP0 Build 4.
