In command screen the control element 'identification of the action variable' can not be insert manually.
Screen type 'command processing: if you try to insert the control element 'identification of the action variable' the control element 'name of the action variable' is inserted instead. Then both are greyed out in the list of control elements. By using a template (e.g. the template 'complete') both control elements are available at the screen.
Renamed duplicated IDs from Editor's menu with controls.
Issue Number: 27301
Fixed on Date: 18.3.2013
Versions: 7.11 0 BUILD 10238
