In command group configured screen is not included in XML export and cannot be set via API
When you XML export a command group, the name of configured screen at the group is not included in the XML file. Only name of screens configured at the individual actions are included in the XML file.
It is also not possible to set the screen name over API.
Updated class use for the property.
Issue Number: 31647
Fixed on Date: 24.11.2015
Versions: 7.60 0 BUILD 36068
The number of alarm group / class / area is not included in the XML export file
Summary It is possible to manually configure the alarm group / class / area number ("Id") in the Editor, however this number is not included in the XML-file when exporting alarm groups / classes / areas Description It is possible to manually ...
Set colors of color palette to zenon elements via API.
Colors in zenon are a 3-byte code of RGB values. The value #EB29D6 corresponds to a strong pink tone. If these colors are linked directly to a zenon object exactly this value is entered in the dynamic property of the element, screen, textcolor, ...
It should be possible to access (get and set) specific driver properties of the drivers MODRTU32, MODBUS_ENERGY and BACnetNG via the API. Furthermore it should be possible to export and import the driver configuration in xml format of these drivers via the API.
Summary Specific driver properties of the drivers MODRTU32, MODBUS_ENERGY and BACnetNG should be accessible (get and set) via the API. Additionally it should be possible to export and import the driver configuration of these drivers in xml format via ...
FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
XML Import/Export for drivers via GUI
Summary Driver configurations can be exported and imported as an XML file from version 12 in Engineering Studio. Description For this purpose, in the driver configuration in the Engineering Studio we added the menu items Export selected as XML and ...
