IMM Maintanance preview filters show no results
In the screen of the Industrial
Maintenance Manager (IMM) type, all pending maintenance tasks are
displayed in a list. When filtering for certain dates, tasks are not displayed,
although they exist.
This error has been fixed. Filters are now applied
correctly and pending maintenance tasks are displayed correctly.
- Update your zenon Software Platform to the latest build of zenon 8.20 or
higher.
Item ID: 242295
Version: 11.00 Build: 157700
Version: 10.00 Build: 131739
Version: 8.20 Build: 150600
GraphQL - Wildcard * sometimes not working for Recources Label and Identification
Description Filters in GraphQL interface sometimes do not provide desired results. If filtering on an empty string, only those objects are displayed that have an empty string at the filtered items. However, the filter should be disabled and show all ...
Comparison Tool: Report does not show correctly Japanese characters
Description If the report of the Comparison Tool is to be viewed in Japanese, incorrect characters are displayed. In the output window of the tool, the characters are still displayed correctly. This behavior has been modified. The Comparison Tool ...
EUROMAP63: In specific scenario when a machine is providing a .DAT file which has the header located in the middle of the file this results in reading in an endless loop by the driver which also leads to a huge amount of log entries in the diag viewer
Description Issue in the EUROMAP63 driver when parsing a DAT file provided by a device, where the header is not in line 0, but in some lines in the middle (e.g. line 9). The driver reads the file in an endless loop, resulting in a large number of ...
