Images are not shown in 'HTML-Help' screen
When using the <NAME_SERVICE_ENGINE> help with
self-created CHM files, no images are displayed in the "HTML help"
screen when the zenon function "Open help" is started. Only
the help text is displayed.
Cause: The images were saved in a folder in which they
were not available for the "HTML-Help" screen.
This error has been fixed. The images for the
<NAME_SERVICE_ENGINE> help are saved in the correct folder again and
displayed correctly.
higher.
Item ID: 274526
Version: 12.00 Build: 206562
FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
Help screen: Alarm-help screen always opens in the most left screen
Description When an alarm has been triggered in the zenon Service Engine, the alarm help screen always popped up in the first screen. The issue has been addressed and the alarm help screen is opened now in the same monitor where the alarm "Open help" ...
The HTML screen does not correctly display certain websites in the runtime
Summary The html screen does not correctly display some web pages in the runtime. Instead of the actual website, e.g. About:blank is shown, or another site is displayed alltogether DescriptionThe html screen does not correctly display some web pages ...
FAQ: Open Report Launcher on the web engine HTML screen
This issue occurs due to cross-site scripting, causing the second HTML screen to be blocked and display a blank screen. It needs to check in IIS if report launcher SSL settings is on "Ignore". And also web engine SSL setting should have the same ...
New HPP Preview images
Summary The images of all hydropower reports have been updated in all Analyzer versions Description The images of all hydropower reports have been updated in all Analyzer versions Issue Number: 201229 Fixed on Date: 6.11.2019 Versions: zenon Analyzer ...
